Ledger Load UNDO Functionality
A Ledger Load Undo operation reverses the effect of the Ledger Load process meaning it deletes the rows that were inserted into a Management Ledger as part of the Ledger Load process.
Figure 6-46 Ledger Load History - Undo
The Undo icon is enabled whenever you select one or more rows from the table.
For details on restricting action to Undo functionality, see User Preferences section. This functionality works only if the Enable Undo for Ledger Load option in the User Preferences is set to Yes.
