Managed Rates
Managed rates are IRC objects that are based on a logical and/or mathematical formula instead of being based on a yield curve. This is useful if you do not have a straight forward application function that generates a rate based on a formula. Managed Rates are formula-driven IRC (interest rate curve or yield curve) objects. The Managed Rates UI provides the following functionalities:
  • Allows to create a managed rates formula with the help of equation builder.
  • You can create a managed rates formula by using existing IRC, Currency, Economic Indicator objects and combining it with various mathematical operators.
  • Execute managed rates using Scheduler Service
Managed Rate Formulas
Managed Rates are free form, user-defined formula, that is, equation based objects. You can use a variety of mathematical, logical, or reference functions to define a Managed Rate. Regardless of the complexity of the function, it always return only one numerical value every time when it is evaluated.
For example, there are three basic inputs for Market Rates formulas:
Numerical and mathematical values, including embedded functions (for example, "SUM" or "AVERAGE").
Existing Rate Management objects such as interest rate curves, economic indicators, and foreign currencies
Reference in time specification, that is, a relative or absolute reference in time either in the past, present, or future.
Formulas are statements. These can be mathematical, logical, or reference one or more Application objects, but it returns a single numerical value.
For example:
Formula input: 1+1
Returns: 2
It is not mandatory to include the "=" symbol in the expression as this is already implied.
There is no nominal value of the rate, that is, it cannot be an accrual, day count, compounding, or other rate identities; it is simply a number.
Basic syntax is required if other service objects are reference, then you must specify three distinct components:
  1. Object type code or name
  2. Object ID
  3. Tenor
  4. Place in time in the forecast
[Object type code].[Object ID].[Tenor if IRC, 0 if anything else].[Place in time]
For example, suppose you want a formula that refers to an interest rate curve's 1 month tenor on a current basis, then its syntax would look something like this:
Figure 6-8 Example of Managed Rate
Here,
[IRC_202] is the IRC code (Object ID)
[1M] is the Term.
[0] is time. This calculates Past, present or future dates/rates with ease for any term/tenor and forecast method definition. The default value is 0. [0] means the now. [-1] refers to back one period. [$] refers to constrained time period.
If the time value falls outside of provided numbers, the Application will refer to the closest matching value. If no value can be retrieved or if the value is null, then the Managed Rate formula will not be evaluated.
Managed Rate Processes
When you validate Managed Rates, it is processed under two conditions:
  1. Managed Rates for Historical Values
    You can use the entered managed rate to derive one or more historical values as specific points in time at or before the current As-of Date.
    Function is executed at the Rate Management level for Managed Rate functions. Specify one or more historical dates that you want to processed and then execute a batch to derive the associated values. All historical values would be stored in a managed rate historical table.
    If a Managed Rate formula has time references that are constrained, the formula will default to the last available value provided. If no value is provided (e.g. value cannot be retrieved or is null), then no rate will be provided for that historical date.
  2. Managed Rates for Forecasted Values
    For forecasted values in an ALM process as established in Forecast Rates. Managed Rates will be forecasted using the forecasted base objects like IRC, Currency and Economic Indicator.
    For more information, see Interest Rate Forecast Methods.
To define Managed Rate, follow these steps:
  1. Select Structure Type as Managed Rates.
  2. Navigate to Managed Rates tab.
    This tab will be active only when Structure Type is selected as Managed Rates.
  3. Select the Function type as Interest Rate Curve, Currency, or Economic Indicator to define a formula.
  4. Double-click the Function code to move it to Formula section.
  5. Update the formula. Use arithmetical operator from Operator to define formula if required.
    Figure 6-9 Formula section
    Formula section
    Interest Rate Curve
    This function evaluates rate of selected term point of Interest Rate Curve, in the past, present or future
    IRC(Name, Term_Point, Time_Reference)
    • Name: Must be an existing IRC
    • Term Point: Must be an existing term point of named IRC
    • Time_Reference: Time_Reference indicates the rate to be forward or backward looking. This should be zero or positive/negative whole number. If left null, replace with zero. 0 indicates current period, positive value indicate forward time and negative value indicates prior period. It can also be relative (moving) or absolute (fixed). Use '$' symbol for absolute Term Reference.
    Currency
    This function evaluates exchange rate of selected currency pair in the past, present or future
    CCY(From_Currency, To_Currency, Time_Reference)
    • From_Currency: Three letter code of active currency
    • To_Currency: Three letter code of reporting currency
    Economic Indicator
    This function evaluates value of selected Economic Indicator in the past, present or future
    ECOIND(Name,Time_Reference)
    • Name: Must be an existing Economic Indicator
    Aggregate
    This includes the following functions:
    Function Description
    Average
    Calculates the average (mean) value of an expression in a result set.
    AVG(expr)
    expr is any expression that evaluates to a numerical value.
    Max
    Calculates the maximum value (highest numeric value) of an expression in a result set.
    MAX(expr)
    Min
    Calculates the minimum value (lowest numeric value) of an expression in a result set.
    MIN(expr)
    Median
    Calculates the median (middle) value of an expression in a result set.
    MEDIAN(expr)
    StdDev
    Returns the standard deviation for a set of values.
    STDDEV(expr)
    Sum
    Calculates the sum obtained by adding up all values satisfying the numeric expression argument.
    SUM(expr)
    Geometric Mean
    Calculates the the geometric mean of an array or range of positive numeric data.
    GEOMEAN(expr)
    At least two values/expression are required to calculate above aggregate functions.
    Math
    Abs
    Calculates the absolute value of a numerical expression.
    ABS(expr)
    Log
    Calculates the natural logarithm of an expression.
    LOG(expr)
    Log10
    Calculates the base 10 logarithm of an expression.
    LOG10(expr)
    Mod
    Divides the first numerical expression by the second numerical expression and returns the remainder portion of the quotient.
    MOD(expr, divisor)
    divisor is any expression or number by which you want to divide
    Power
    Takes the first numerical expression and raises it to the power specified in the second numerical expression.
    POWER(expr, power)
    power is the exponent, to which the base expression or number is raised
    Round
    Rounds a numerical expression to n digits of precision.
    ROUND(expr, num_digits)
    num_digits is the number of digits to which you want to round. Negative rounds to the left of the decimal point; zero or omitted, to the nearest integer.
    Round Down
    Rounds down a number to either a decimal place or a whole number.
    ROUNDDOWN(expr, num_digits)
    Round Up
    Rounds up a number to either a decimal place or a whole number.
    ROUNDUP(expr, num_digits)
    integer is any positive integer that represents the number of digits of precision.
    Sqrt
    Calculates the square root of the numerical expression argument.
    SQRT(expr)
    expr is any expression that evaluates to a nonnegative numerical value.
    Product
    Multiplies all numerical expressions given as arguments and returns the product.
    PRODUCT(expr1, expr2)
    Quotient
    Returns one numerical expression divided by numerical expression, without the remainder.
    QUOTIENT(expr1, expr2)
    Example: QUOTIENT(5,2). This will return 2, unlike division which returns 2.5
    Exponent
    Calculates e raised to the power of the numerical expression argument.
    EXP(expr)
    Expression
    Case(If)
    This form of the Case statement evaluates each WHEN condition and if satisfied, assigns the value in the corresponding THEN expression. If none of the WHEN conditions are satisfied, it assigns the default value specified in the ELSE expression. If no ELSE expression is specified, the system will automatically add an ELSE NULL.
    CASE WHEN request_condition1 THEN expr1 ELSE expr2 END
    exprs is any valid expression.
    For IRC Managed Rates, the Historical Rates tab is view-only. You cannot add or edit the historical rates.
  6. Click Apply and Validate. A successful formula validation message is displayed. After clicking Ok, you will be navigated back to Interest Rate Summary page.
  7. Enter From Date and To Date.
  8. Click Generate. This button will be activated after successful validation of formula. A batch Id is generated, You can use this Id to monitor the progress in Scheduler Service.
  9. After defining and verifying the Managed Rates, you can execute the IRC using scheduler service.
Executing Managed Rates using Scheduler
To execute the batch, navigate to Operations and Processes and select Scheduler. Select Schedule Batch and search for Historical Managed Rates and execute.
OR
You can also define new batch to execute the Managed Rates by the following these steps:
  1. Navigate to Operations and Processes, select Scheduler, and then select Define Batch.
  2. Create a new Batch with a new Task with Component as IRC Managed Rates.
  3. From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Schedule Batch to execute the batch. Select the batch and click Execute. For more details about Scheduler processes, see the Scheduler Services.
  4. From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Monitor Batch. There may be multiple executions of the batch. Select the latest execution and click Start Monitor.
    The UI displays the status of the batch.
