Managing Dashboard Data
The information displayed in the dashboard is maintained through service executions and API registrations.
Refreshing Dashboard Information
By default, tenant statistics are gathered daily at 00:00 AM (UTC). If required, users can also trigger this on demand from the UI or through the scheduler service by defining a batch (select component name as "Tenant Dashboard") and task.
- Navigate to the Batch Maintenance screen.
- Select the batch associated with Tenant DB Info Refresh..
- Trigger the execution.
This process refreshes statistics for all schemas listed in the List of Schema to Gather Storage Stats.
Dashboard data is automatically refreshed by a pre-seeded, non-editable batch that runs on a fixed schedule:
Table 5-14 Dashboard data
| Parameter | Value |
| Batch ID | PBSM_TENANT_STATISTICS |
| Batch Name | PBSM_TENANT_STATISTICS |
| Task ID | DATABASESTATISTICS |
| Task Name | DatabaseStatistics |
| Run Frequency | Daily at 00:00 AM (UTC) |
- OFSAAMETA
- PBSMDD
- OFSAACONF
- OFSAALOGS
- CUSTOM
- OFSAAMETACONF
- OFSAA_ANALYTICS_PUB
Only objects of type TABLE are scanned for storage data. The batch frequency and scheduled time cannot be changed by users.Viewing Execution Logs
View the last execution logs:
Table 5-15 Viewing Execution Logs
| Field | Description |
| Batch Run ID | Unique identifier generated for the execution. |
| Task ID | The specific task executed (for example, DATABASESTATISTICS). |
| Status | Execution result: SUCCESS, ERROR, or IN PROGRESS. |
| Start Time | Timestamp when the execution began. |
| End Time | Timestamp when the execution completed. |
| Executed By | The user account or scheduler that triggered the run. |
| Snapshot Date | The as-of date for which statistics were gathered. |
Troubleshooting
Use the table below to resolve common issues with the Tenant DB Dashboard:
Table 5-16 Troubleshooting Issues
| Issue | Resolution |
| Dashboard shows no data | Verify that the PBSM_TENANT_STATISTICS batch has run at least once. Use Gather Tenant Info for an on-demand execution. |
| Historical trend chart is empty | The chart requires at least one historical data point. Data is shown for the last 6 months only. |
| Dynamically created table not visible | Register the table using the POST /tenant-dashboard/v1/registerTablesToCategory API with a valid schema and categoryId. |
| Tenant Statistics menu not visible | Confirm your account has the RLTENANTSTATSVIEW role and the TENANTSTATISTICSVIEW function assigned. |
| Stale statistics warning on a table | Informational only. Trigger a new batch run to refresh table statistics. |
| 400 error from Registration API | Verify that the schema and categoryId values in your request are from the supported lists. |
