Managing Form Definitions
You can view, edit, copy, and delete the existing Form Definitions from the Form Definition Summary Page, based on the assigned roles.
To check about the assigned roles, refer to User Role Mapping and Access Rights.
In the Summary Page, highlight a specific Definition and click Action. The following options are displayed:
Table 4-22 Action Details
Action Description
View View the Member details for a specific Member Definition.
Edit/Amend Edit/amend the Member details of a form definition.
Copy Copy the Member Definition Details and create another Member Definition by changing Alphanumeric Code, Numeric Code and Name.
Re-Upload Upload a new Excel sheet for an Excel upload form definition. You need to delete the attached excel sheet before uploading the new data.
Delete
Approve If you have the required role, you can approve a new Form that is in Awaiting Approval status. For more information, refer to Approving a Forms Definition.
Reject If you have the required role, you can approve a new Form that is in Awaiting Approval status. For more information, refer to Rejecting a Forms Definition.
