Prepayment Model Analysis
The Prepayment Model Analysis module allows you to develop a model for prepayment rate calculations as per the chosen risk factors. Model building could be a time consuming process given huge data sets and limited IT infrastructure.
User Roles and Privileges
| Purpose | Role Code | Role Name | Function Code | Function Name |
| Prepayment Data Generation | RLPPMTADMIN | Prepayment Model Data Generation Admin Role | PPMTDATAADD | Add Prepayment Model Data Creation Process |
| PPMTDATARUN | Run Prepayment Model Data Creation Process | |||
| PPMTDATADEL | Delete Prepayment Model Data Creation Process | |||
| PPMTDATAEDIT | Edit Prepayment Model Data Creation Process | |||
| PPMTDATACOPY | Copy Prepayment Model Data Creation Process | |||
| PPMTDATAVIEW | View Prepayment Model Data Creation Process | |||
| RLPPMTANALYST | Prepayment Model Data Generation Analyst Role | PPMTDATAADD | Add Prepayment Model Data Creation Process | |
| RLPPMTAUDIT | Prepayment Model Data Generation Auditor Role | PPMTDATAVIEW | View Prepayment Model Data Creation Process | |
| Prepayment Model Analysis | RL_PPMT_ANALYSIS_ADMIN | Prepayment Model Analysis Admin Role | PPMT_ANALYSIS_ADD | Add Prepayment Model Analysis |
| PPMT_ANALYSIS_DEL | Delete Prepayment Model Analysis | |||
| PPMT_ANALYSIS_EDIT | Edit Prepayment Model Analysis | |||
| PPMT_ANALYSIS_COPY | Copy Prepayment Model Analysis | |||
| PPMT_ANALYSIS_VIEW | View Prepayment Model Analysis | |||
| RL_PPMT_ANALYSIS_ANALYST | Prepayment Model Analysis Analyst Role | PPMT_ANALYSIS_ADD | Add Prepayment Model Analysis | |
| RL_PPMT_ANALYSIS_AUDIT | Prepayment Model Analysis Auditor Role | PPMT_ANALYSIS_VIEW | View Prepayment Model Analysis |
Prepayment Model Analysis Rule Summary
Figure 6-126 Prepayment Model Analysis Rule Summary
Search Prepayment Model Analysis Rule
Prerequisites: Predefined Prepayment Model Analysis Rule
To search for a Prepayment Model Analysis Rule:
Click Search after entering the search criteria. The search results are displayed in a table containing all the Prepayment Model Analysis Rules that meet the search criteria.
Or
An alternative method to search a Prepayment Model Analysis rule is through the Field Search option. This is an inline wildcard UI search that allows you to enter a search value (such as code, name, etc.) partially or fully. Rows that contain the string you are searching for are fetched and displayed in the Prepayment Model Analysis Summary. You can enter the Code, Name, Description, Dimension, Hierarchy, and Folder of the Prepayment Model Analysis Rule and click Search .
The Prepayment Model Analysis rule Summary displays the following information:
Add: Click the Add icon on the page header to build a new Prepayment Model Analysis rule.
More Actions: Enables you to perform following tasks.
- Refresh: Refreshes the summary page with latest model status.
- Reset:Clears all fields back to default.
- Help:Redirects you to latest documentation.
Delete: Enables you to select and delete one or multiple rules in the table simultaneously.
Pin/Unpin: Enables you to pin/unpin the selected rule.
Export: Enables you to download the summary page details in .CSV format.
Columns: Allows you to view the summary page data using a customized list of columns.
The Prepayment Model Analysis summary table displays the following columns:
- Model Name: The Prepayment Model Analysis Rule's short name.
- Model Type: Shows the type of Prepayment Model Analysis rule as Linear or Polynomial
- Status: Displays the status as Draft or Completed.
- Folder: The Folder where the Prepayment Model Analysis Rule is saved.
- Created By: The user who created the Prepayment Model Analysis Rule.
- Created On: The Date and Time when the Prepayment Model Analysis Rule was created first.
- Last Modified By: The user who last modified the Prepayment Model Analysis Rule.
- Last Modified Date: The Date and Time when the Prepayment Model Analysis Rule was last modified.
- Action: Click this icon to view a list of actions that
you can perform on the Prepayment Model Analysis rule.
- View/Edit: Based on the user privilege assigned, you can either only view or edit existing Prepayment Model Analysis rules. To edit a rule, you must have Read/Write privilege.
- Save As: You can reuse a Prepayment Model Analysis rule by saving it under a new name thus saving time and effort in entering data multiple times; it also leads to reduced data entry errors.
- Delete: You can delete Prepayment Model Analysis rules that you no longer require. Note that only Prepayment Model Analysis rule owners and those with Read/Write privileges can delete Prepayment Model Analysis rules. A Prepayment Model Analysis rule that has a dependency cannot be deleted.
- Dependency Check: You can perform a dependency check to know where a particular Prepayment Model Analysis rule has been used. Before deleting a rule, it is always a good practice to do a dependency check to ensure you are not deleting Prepayment Model Analysis rules that have dependencies. . A report of all rules that utilize the selected Prepayment Model Analysis rule is generated.
Also See:
