Request JSON Parameters
This section provides the list of parameters in the JSON Request.
Table 4-15 Request JSON Parameters
Name Type Required Description
fileName STRING Yes The name of the file to be uploaded.
The following are the conditions for to enter in this field:
  • Must start with an Alphanumeric Character
  • Allowed characters are alphabets, numbers, and special characters - hyphen(-), dot(.), and underscore(_)
  • Length of characters must not be greater than 255 characters
fileSize INTEGER Yes The size of the file (in Bytes) to be uploaded.
The size of the file should be greater than 1 Byte and should be less than 10 TB.
It is recommended to use multipart upload for uploading files of size more than 100 MB. For more information about uploading large objects and multipart uploads, refer to Working with Pre-Authenticated Requests.
mimeType STRING Yes The mime type to be uploaded.
The following mime types are allowed:
  • Text/CSV
  • Text/plain
  • DAT
Request JSON Sample
"fileName": "File.csv",
"fileSize": 7654,
"mimeType": "text/csv"
