Target Instrument Table Selection
The Target Instrument Table Selection pane defines the instrument table and target column that the Lookup Table operates against.
  • Target Table Selection: Select the instrument table from the drop down. The list is limited to the instrument tables available in Profitability Management Cloud Service.
  • Target Column Selection: Select the target column from the selected instrument table.
The following options are available in this pane:
  • Add Lookup Key Column: Adds a lookup key column to the Lookup Key Columns grid based on the selected table and column.
  • Add Return Column: Adds a return column to the Lookup Key Columns grid.
