UI Based Procedure
To execute the Data Creation Process, follow these steps:
  1. Navigate to the Data Creation Process Summary Page.
  2. Search for a Data Creation process Rule.
  3. Click the Action column and select Execute to execute an existing Data Creation Process.
    Figure 6-143 Execute Data Creation Process
  4. Select As of Date and click Submit.
  5. The Data Creation Process Run Confirmation Page is displayed. The status of the process is displayed in the Status column.
    After completion of the process, you can navigate to the Execution Details Page by selecting the view log option. From the Execution Details, you can access a report that provides details of any processing errors that were encountered while running the data creation process.
