Upload or Download File Using Console
  1. From the left menu, click Common Object Maintenance.
  2. Click Data Management in the left navigation pane.
    The File Upload and Download page is displayed. The files that are uploaded to the Object Store are listed here. The following details are provided for each File.
    • File ID - The unique file ID associated with the file. This is auto-generated during the upload.
    • Prefix - The prefix is added to the file name.
    • File Name - The name of the file that is uploaded. This is automatically updated after you select the file.
    • Stripe Name - The unique identifier for storing a collection of files. Collection examples: Project, organization, tenant.
    • Uploaded Date - The file upload date with timestamp.
      The timestamp is displayed according to the time zone selected on the Preferences screen. After selecting a time zone, users must log out and log back in for the change to take effect. This is a one-time configuration.
    • Download File - Click to download a copy of the uploaded file.
    • Delete - Click to delete the file.
  3. Click Upload on the File Upload/Download Summary screen.
  4. Click Drag and Drop to browse and select a file for upload from the local directory.
    You can also browse to the local directory from the File Explorer and select the file and drop it here.
    The file name is automatically updated in the Selected File field.
  5. Prefix: You can upload a file with or without a prefix. If you need to upload two files that have the same name, use different prefixes to keep them unique.
    Use the left pane to view the prefix hierarchy and identify the exact folder where your file is stored.
    • By default, the Summary page shows only files without a prefix.
    • To display all files (with and without prefixes), select the Show All Files check box.
      • While this check box is selected, the prefix navigation in the left pane is locked.
      • To resume using the left pane, clear the check box.
  6. Click Upload to upload the selected file.
    A confirmation message is displayed after successful upload and the file is listed in the Uploaded Files list.
    Downloading file(s)
    Complete the following steps to download a single file.
    1. Click the Actions menu corresponding to the file you want to download and select Download.
    2. Specify a name (optional) and file type (optional).
    3. Click Save.
    Complete the following steps to download multiple files at once.
    1. Select the checkbox corresponding to each file you want to download.
    2. Click the Download Multiple Files icon (top right corner).
    3. Specify a name for the compressed folder type.
    4. Click Save
    Deleting file(s)
    Complete the following steps to delete single file.
    1. Click the Actions menu corresponding to the file you want to delete and select Delete.
    2. Select Yes to confirm the deletion.
    Complete the following steps to delete multiple files at once.
    1. Select the checkbox corresponding to each file you want to delete.
    2. Click the Delete Multiple Files icon (top left corner).
    3. Select Yes to confirm the deletion.
