View redaction policies
You can view the defined redaction policies using the Redaction Policies Summary screen.
To view the redaction policies:
  1. Click Data Management Tools > Redaction Framework and select Redaction Policies.
    The Redaction Policies Summary screen appears.
  2. Enter the text of the second step here.
    See the table below for fields and their description.
    Table 4-31 Redaction Policies Summary
    Field Description
    Classification Name Pre-seeded classification code name.
    Redact Functions Redact function name
    Version The latest version of the classification.
    Request Type Types of request:
    • Refresh: Map redaction as per latest addition of table columns.
    • Unmap: Remove redaction.
    • Map: Apply redaction
    Status Policy status
    Policy Applied On Date on which the policy was applied.
    Created By The user who created the policy.
    Created Date Date of creation of the policy.
    Actions You can perform the following actions:
    1. Edit
    2. Drop
    3. Refresh
    4. View
  3. Click the Actions menu corresponding to the policy you want to view and select View.
The Redaction Policies Preview screen appears containing details of the policy.
