AutoObjectStore Utility
The AutoObjectStore utility is a command-line utility for automating object-store file operations and selected application operations. You can use the utility to upload, download, delete, and generate pre-authenticated request (PAR) URLs for files. It also supports batch execution and status monitoring, data loading, application as-of-date management, and data-export manifest retrieval.
Download the `AutoObjectStore.zip` utility from the **Data File Upload and Download** page. Extract the archive on a host from which you can access the service.
