Activate Currency
You must activate a currency before it can be used as a Reference Currency, before entering Exchange Rate data, defining Forecast Rates, or defining other business rules for that currency.
To activate one or more Currencies, follow these steps:
  1. Navigate to Reference Data and select Currency.
  2. In the Currency Summary table, select the check box next to one or more Inactive Currencies.
    This enables the Activate button on the toolbar.
  3. Click Activate. Alternatively, click the Action icon for a single Currency and select Activate from the menu.
  4. The Status of the selected Currency or Currencies changes to Active in the Currency Summary table.
    The Activate option is disabled (greyed out) in the Action menu for a Currency that is already Active.
