Adding a Lookup Table
To add a Lookup Table:
  1. Click Add on the title bar.
    Figure 4-32 Adding a Lookup Table
  2. Enter the following details under Lookup Table Details:
    • Code
      • The code can be entered manually by the user or generated automatically.
      • Only numerical values are allowed; special characters are not permitted.
    • Name
    • Folder Name
    • Description
    • Access Type: Read Only or Read/Write
    • Use As Of Date Filter toggle switch: As applicable.
    Click Show Sample CSV to download the CSV template required by the Scheduler Service Lookup Table Data Loader. Use this template to prepare your lookup table data before importing it.
  3. Enter the following details under Target Instrument Table Selection section:
    • Target Table Selection: Select the relevant table that you want to change/update the data.
    • Target Column Selection: Seelct the relevant column that you want to set the condition on the selected Target Table.
    • Add Lookup Key Column: Select the following options as applicable:
      • Exact Match
        • Range Lookup
      • Code Match
      • Code Pattern Match
      • Hierarchy – ID Match: In this case, you must select the Hierarchy of the selected Dimension. Staggered hierarchies with multi-level nodes are also supported. In lookup data, you can use nodes at multiple levels on the selected hierarchy, system is able to figure out leaf nodes on which lookup table need to be executed. Provide the hierarchy ID.
      • Hierarchy – Code Match: In this case, you must select the hierarchy of the chosen dimension. Staggered hierarchies with multi-level nodes are also supported. In the lookup data, you can use nodes at multiple levels of the selected hierarchy, and the system is able to determine the leaf nodes on which the lookup table needs to be executed. Provide the hierarchy code.
    • Add Return Column.
  4. Enter the following details under Lookup Key Columns section:
    • Lookup Type:
      • Exact Match
      • Range Lookup
      The Audit Info part of the screen displays the following details:
      • Created By
      • Created Date
      • Modified By
      • Modified Date
      • Authorized By
      • Authorized Date
  5. Click Save. The newly added Lookup Table definition is added to the summary screen and displayed.
    After the definition is saved, you can select the definition from the summary screen and clickView from Action menu.
    You can see the Show Sample CSV and Lookup Table Data buttons are enabled.
    When you click the Show Sample CSV button, the system downloads a CSV file. You can feed the details in this sheet.
    When you click the Lookup Table Data button, the system displays the Lookup Table Data in edit mode.
    Two physical tables are created in the database: one with the STG_ prefix and one without the prefix.
From this screen, you can manually Add or Delete a row, export or import a CSV file. Click Import, navigate to the location where you have your XLS file, select and import.
