3.2.4.2 Common Icons
Use the icons to view and analyze data and related information for each features.
Table 3-7 Common Icons
Icon Name Icon Uses
Add
Figure 3-16 Add icon
Add icon
Click Add icon to build a new rule.
Refresh
Figure 3-17 Refresh icon
Refresh icon
Click to refresh the Summary Page.
Help
Figure 3-18 Help icon
Help icon
Click to view the Holiday Calendar Rule Help.
Multiple Delete
Figure 3-19 Multiple Delete icon
Select one or more rules in the table and then click the (-) icon at the top right of the Summary Page to delete more than one rule at the same time.
Search
Figure 3-20 Search icon
Search icon
To Search the rule(s)
List View
Figure 3-21 List View
List View
To view the Rule Summary Page items in List View.
Table View
Figure 3-22 Table View
Table View
To view the Rule Summary Page items in Table View.
Ascending and Descending
Figure 3-23 Ascending icon
Ascending icon
and
Figure 3-24 Descending icon
Descending icon
To sort the rules on Rule Summary Page.
Action
Figure 3-25 Action icon
Action icon
Click to perform view various action options.
View/Edit
Figure 3-26 Edit icon
Edit icon
Click in the Action column and select View/Edit to view or edit the contents of a rule in Read/Write format. Depending on User Privileges, the rule will open in either View or Edit mode.
Copy or Save As
Figure 3-27 Save As icon
Save As icon
Click in the Action column and select Save As to create a copy of an existing rule.
Delete
Figure 3-28 Delete icon
Delete icon
Click in the Action column and select Delete to delete an existing rule.
Execute
Figure 3-29 Execute icon
Execute icon
To execute a process
Execution Details
Figure 3-30 Execution Details icon
To view the execution details of the process.
Add New
Figure 3-31 Add New icon
Add New icon
Click Add icon to add new items on Rule screen.
Add Multiple Rows
Figure 3-32 Add Multiple Rows
Add Multiple Rows
Click Add Multiple Rows to add multiple rows at a time.
Add Row
Figure 3-33 Add Row
Add Row
This allows you to Add one Row at a time.
