Create Behavior Pattern Rules
You create behavior pattern rules to capture the principal run-off behavior of product types that do not have contractual maturities.
To create a Behavior Pattern rule, follow these steps:
  1. Click Add icon from the top of the Behavior Pattern Rule Summary page.
    Figure 6-76 Create Behavior Pattern Rule
  2. Enter the following Details.
    Table 6-15 Create Behavior Pattern Rule
    Fields Description
    Code Enter the code manually, or click Autogenerate to generate it automatically.
    Name Enter the name of the Behavior Pattern Rule.
    Description Enter the description of the Behavior Pattern Rule. This is an optional field.
    Folder Select the Folder where the Behavior Pattern Rule needs to be saved.
    Access Type Select the Access Type as Read-Only or Read/Write.
  3. Click Apply. The Behavior Pattern Rule page is displayed:
    Figure 6-77 Behavior Pattern Rule Page
    Click Save button to save the draft of Behavior Pattern Rule.
    The Detail Info shows the basic details of rule, such as, Behavior Pattern Rule Name. Description, Folder Name, and Access Type.
    The Audit Info shows the audit details of rule.
  4. Select the Dimension as Common Chart of Accounts, Product, General Ledger Account, or MDBSS.
    MDBSS is enabled only in ALM Cloud Service.
    If any member is a currency in the MDBSS hierarchy (for example, INR) and selected currency is different (for example USD), then the member and its children nodes cannot be defined.
    You can search the rule on any of the product dimension, searched dimension will be auto-populated while defining the rule; if you like, you can change the default product dimension.
  5. Select a Currency.
  6. Select Folder and Hierarchy.
  7. Select Member Node(s) from Member Tree of Assumption Browser. The Assumption Browser has following two tabs: Member Tree and Search Results
    • Member Tree: Member Tree tab shows the hierarchical structure and allows you to define rules by selecting the node members from the browser. Select Node and Click Menu icon next to it to view the available options.
      Figure 6-78 Member Tree
      Member Tree
      Status of node is also displayed in Member Tree section, for example Selected, and so on. To select member hierarchy, following options are available:
      • Expand self, child and descendants: Allows to expand the selected node itself along with its child and descendants.
      • Expand selected member/branch: Allows to expand the selected node
      • Select UnSelect self, child: Allows to unselect the selected node itself along with its child
      • Select UnSelect self, child and descendants: Allows to unselect the selected node itself along with its child and descendants.
      • Select Defined self, child: Allows to select the selected node itself along with its child.
      • Select Defined self, child and descendants: Allows to select the selected node itself along with its child and descendants.
      • UnSelect self, child and descendants: Allows to unselect the selected node itself along with its child and descendants.
      Use Show Numeric Code Values (Left) icon to view the code value left to the Node name.
      Use Show Numeric Code Values (Right) icon to view the code value right to the Node name.
      Here, you can perform the following tasks on the selected node(s):
      • Add
      • Edit
      • View
      • Delete
      • Copy
    • Search Results: You can also search the members based on the filters. This section shows the searched node(s). To search a member, follow these steps:
      1. Navigate to Assumption Browser section of the Rule Definition page.
        Before using the Member Search in Assumption Browser, you must execute the batch Member Browser Refresh. For more information, see note in Create MDBSS section.
      2. Enter the Member ID, Name, Status, or Is Leaf in Search Criteria.
        Figure 6-79 Search Criteria
        Search Criteria
      3. Click Search. The searched member(s) will be displayed in Search Results section of Assumption Browser
        Figure 6-80 Searching Members
        Searching Members
        Here, you can perform the following tasks on the searched node(s):
        • Add
        • Edit
        • View
        • Delete
        • Copy
      Click Show Parentage icon to view the Parent-child Node level hierarchy details of selected Node.
  8. Click Add from Assumption Browser section.
  9. Click Save.
