Creating the Data File
After the Data File Specification is defined, follow the below mentioned guidelines to prepare the Data Files:
- Columns to be included in the Data File must be as per the Data File Specification.
- Name of the Data File can be user defined. The following example gives
an idea of what the Data File Name can be:
- Data File Specification Name is “Asset.dat”
- The As of Date is 06-July-2022
- Name of file uploaded to object store can be like “input_20220706_loanasset.dat” or “input_20220706_asset.dat”
The prefix (input_yyyymmdd) is mandatory in actual file name when uploaded to Object Store but is not required while you enter the name in the Task Parameters UI against the Data File Name.
- Unique Data Validations:
- Instrument Data Files: Account Numbers must be unique across the data files for a single As of Date.
- Management Ledger Data Files: The combination of AS_OF_DATE, CONSOLIDATION_CODE, ISO_CURRENCY_CD, all seeded and placeholder Key Processing Dimensions (KPDs), and DATA_SOURCE_CODE must be unique across the data files for a single As of Date. This allows loading logically identical Management Ledger data more than once for the same As of Date, provided a unique DATA_SOURCE_CODE value is used for each load. Beginning with release 26C Release, DATA_SOURCE_CODE is a mandatory (NOT NULL) column in all six Stage Management Ledger tables.
- Transaction Summary Data Files: The combination of Account Numbers and KPDs must be unique across the data files for a single As of Date.
- Permitted Delimiters are comma (,) and pipeline (|).
- Data Validations:
- Number fields: only numbers and dot (.) are allowed.
- Description fields: comma (,) pipeline (|), single quotes (‘’), and double quotes (“ “) are not supported.
- Any nullable fields which are mapped in the Data File Specification definitions should not skipped in the Data File.
- The Data Source column in all Stage Management Ledger and Processing Management Ledger tables defaults to -1. You can therefore choose not to include the Data Source column in the input Data File / Data File Specification.
- The column order in the Data File should be in sync with the order defined in the Data File Specification definition.
- Field Enclosures: Only double quotes (“”) are considered as Field Enclosures.
See the following sample files for your reference:
For more information about the data required by the Profitability and Balance Sheet Management Cloud Services, see the Data Requirements available at the Doc ID: 2869409.1.
