Data Model Extension
Customization of Physical Data Model is restricted in the Cloud Service. However, there may be a need to extend the Data Model to meet multiple business requirements. For this purpose, the Cloud Service provides OOTB placeholder Columns and Tables that can be configured to use as custom Columns, Custom Dimensions, and Custom Management Ledger Tables as suitable to the business requirements.
The Data Model Extension summary screen displays the available registration categories as tiles. Each tile shows the number of objects that are already registered and the number of placeholder objects still available for registration.
Figure 4-1 Data Model Extension summary screen
- Dimensions: Displays Simple Dimension and Key Processing Dimension tiles.
- Columns: Displays placeholder column categories such as Rate, Volume, CHAR, Long Description, Flag, and Balance. Use the navigation arrows to view additional column categories, if available.
- Management Ledger: Displays existing Management Ledger registrations and the Add Management Ledger option.
- Pending Registration: Displays pending Dimension and Column registration counts.
The Data Model Extension summary screen also provides Refresh and Help options, available at the top-right of the screen, to reload the latest registration counts and access contextual help.
The Management Ledger tables are applicable only to Profitability and Balance Sheet Management Cloud Services.These placeholder Columns and Tables must be registered before use. The Data Model Extension Module allows you to do the following types of registrations:
- Dimensions Registration
- Columns Registration
- Management Ledger Registration
After registration, you can start loading the data in the selected placeholder Columns and Tables and use them to define the Rules and Assumptions for further processing and reporting.
Appropriate user roles must be created and maintained for the users to perform the registration and registration approval processes.
To register the placeholder Columns and Tables, from the LHS Menu, select Data Management Tools, and then select Data Model Extension to display the DataModel Extension summary screen.
The Data Model Extension summary screen displays the following tiles:
- Dimensions
- Columns
- Management Ledger
Using this UI, you do the registration of Dimensions, Columns, and Management Ledger Tables. After the registration is done, the detail will be sent to the Supervisor or Approver User who either approves or rejects the registration.
Configuration of custom columns, dimension and tables must be same across all your environments. For example: If ‘Key Placeholder Dimension 01’ is registered as ‘Custom Dimension One’ in development environment then it must be same in all other environments to avoid logical mismatches. Hence, it is recommended to always use Object Migration for Data Model Extensions to keep environments synchronized.
