General Configuration
The General Configuration menu allows you to configure the parameters related to a scheduler service.
  1. Under Scheduler Configuration menu, click Configure corresponding to Global Scheduler Configuration option.
  2. Click Edit to modify the configuration settings.
  3. Modify the required details, refer to the General configuration parameters table below.
    Table 7-3 General configuration parameters
    Parameter Description Default Value
    Enable/disable general email notification Enable/disable general email notifications to automatically alert users when a batch job is successful, failed, or is interrupted. Enable
    Enable/disable in-app notification Enable/disable in-app notifications to alert users within the application when a batch job is successful, failed, or is interrupted. Enable
    Enable/disable notification for threshold email Enable/disable email notifications triggered when a batch execution exceeds its expected execution time threshold. For example, if a batch typically completes in 1 hour but now takes longer, an email is sent as its taking longer than expected time to complete. Enable
    Threshold email time notification percentage criteria Defines the additional execution time (in percentage) allowed beyond the last successful batch completion time before sending a threshold notification email.
    For example: If a batch previously completed successfully in 1 hour and the threshold is set to 20%, a threshold notification will be triggered if the batch exceeds 1 hour and 12 minutes (i.e., 60 minutes + 20%).
    If multiple notifications are allowed (as per the Threshold email Notify Limit), the time for subsequent notifications will be calculated from the last notification time, adding the same threshold percentage again.
    For instance, the next notification would be triggered after 20% of 72 minutes (i.e., 86.4 minutes), and so on.
    20
    Threshold email Notify Limit Defines the maximum number of email notifications that can be sent when a batch exceeds its execution time threshold during a single run.
    If general email notification is disabled and only if the threshold email notification is enabled, scheduler sends only the threshold email.
    5
    Batch to User mapping upper limit Specifies the maximum number of users that can be mapped to a batch/batch group. You can configure a maximum of five user mappings per batch or batch group. 10
    System pause on batch failure Controls system pause and dependent schedule skip behavior on batch failure. Enable
  4. Click Save to save the modified configurations.
    OR
    Click Cancel to discard the changes and revert to the previous settings.
