3.1.7.2 Get the OAuth Client ID and Client Secret
An OAuth Cliend ID and Client secret are required to generate an access token.
You can obtain the OAuth client ID and client secret from:
  1. Integrated application (recommended): Obtain the Client ID and Client Secret from the newly created Integrated (Confidential) Application.
  2. OPC application (will be deprecated in a future release): From the Oracle cloud services tab in your OCI Console, open your tenant-specific application and obtain the client ID and client secret.
Once you obtain the client ID and client secret, proceed to generate the access token
