3.2.3 Guidelines for Working with a Cash Flow Engine
This topic describes an approach to designing and building applications based on your Security Role and the tasks it enables you to perform.
For CFE Administrators
CFE Administrators can perform the following steps to set up Cash Flow Engine:
  • Define the folders before creating the assumptions, rules, and processes.
  • Extend the Data Model, if required, by registering placeholder columns and tables.
For CFE Analysts
CFE Administrators and Analyst Users of Cash Flow Engine can perform the following steps to set up an application:
  • Activate one or multiple Currency
  • Define dimensions (such as business dimensions, and so on) using Dimension Management to build the main objects within the application.
  • Define Global, User, and Application Preferences
  • Define the Interest Rates and Economic Indicators
  • Create assumptions and rules.
  • Define Cash Flow Process and Cash Flow Edits Processes
  • Load the data.
  • Create and execute the batches
  • Validate the Cash Flow Engine Application Structure to ensure that the application structure confirms to Validation Rules.
  • Set up analysis views and other analytic tools so those with User and Viewer Roles can use them.
  • Analysis the results.
For CFE Auditor
All users, including CFE Auditor, can do most of the following:
  • View rules and assumptions setup in Cash Flow Engine.
  • Analyze the Calculated Result Reports.
  • Use the analytics features to track and report on Cash Flows.
