3.6.3.2 Mapped/Unmapped Functions
As an Administrator, you can map/unmap a role to/from a function user group from the Roles Summary page.
To map/unmap roles to functions:
  1. Select the role name in the Roles Summary page.
  2. Select Mapped Functions to access the list of functions mapped to the specific role. Each identity object displays the current status of its mapping. The status can be one of the following:
    • Approved
    • Waiting for Mapping
    • Waiting for Unmapping
  3. To map roles to functions:
    1. Click New Mapping.
      The list of user functions you can map the role to appears in the Available Functions page.
    2. Select the check box corresponding to a function or click Select All to select all the available functions.
    3. Click Map.
      A confirmation message is displayed after successful mapping. The mapping will be completed after authorization.
  4. To unmap roles from functions
    1. Select the check box corresponding to a function or click Select All to select all the available functions.
    2. Click Unmap.
      A confirmation message is displayed after successful unmapping. The unmapping will be completed after authorization.
  5. After mapping/unmapping a function, ensure to authorize it accordingly. To authorize a mapping/unmapping:
    1. In Mapped Functions, select the role-function mapping or unmapping that requires approval.
    2. Click Authorize/Reject to approve or cancel the mapping/unmapping request.
