Modifying Credentials Post-Subscription
Even after a successful subscription with Integrated App Migration enabled, an ADMIN user retains the ability to modify the Client ID and Client Secret. To update credentials:
  1. Navigate to Admin Tools > Data Foundation Integration > Data Services Subscriptions.
  2. Select the subscribed PBSM Application Data Services entry and click Edit Subscription.
  3. Verify that Integrated App Migration remains selected. The check box is read-only after migration.
  4. Update the Client ID and/or Client Secret fields as required.
  5. Click Update Credentials to save the changes.
  6. Click Test Connection to verify the updated credentials.
  7. After a successful test, click Update Credentials.
  8. Run an ADS batch and verify successful completion in ADS Run History.
    Table 5-8 Field Reference Table
    Field Description Editable Post-Subscription
    Integrated App Migration Checkbox to enable migration to Integrated App model No (irreversible)
    IDCS URL Identity Cloud Service URL No
    DFCS URL Data Foundation Cloud Service URL No
    Client Id Client ID of the Confidential/Integrated App (from OPC Support) Yes (Admin only)
    Client Secret Client Secret of the Confidential/Integrated App (from OPC Support) Yes (Admin only)
    DFCS Tenant Id Tenant identifier in DFCS No
    User Id Administrator user ID Yes
    Password Administrator password Yes
