Running the utility
To start the interactive utility, run the following commands from the extracted directory:
cd bin
./pbsm-automate
The utility displays the available operations. Operation names are not case-sensitive.
To run an operation without using the interactive menu, use this syntax:
./pbsm-automate <operation> <parameters>
For example:
./pbsm-automate push File1
Run one operation for one input at a time. Do not use comma-separated multiple inputs in a single invocation. When an operation requires a file path, specify the path using double forward slashes, for example `//path//to//file`.
