3.6.1 Users Summary Page
The Users Summary page shows the list of available users. You can view the details of a user and map the user to one or more user groups.
To access the Users Summary page:
  1. Click Identity Management tab in the Admin Console page.
  2. Click the Users tile to access the Users Summary page.
  3. Select a specific user name in the Users Summary page and then click Details to view the associated User ID and User Name.
  4. Select a user name and click Mapped Groups to view the list of groups that are mapped to the particular user.
    To map/unmap a user group, refer to Mapped and Unmapped Groups.
    To search for a specific user, type the first few letters of the user name that you want to search in the Search box and click Search. The results will show users matching your input.
    At the bottom of the page, adjust the number of entries displayed per page using the up and down arrows in the Records box. To navigate between pages in the View bar, use these buttons:
    • First page to go to the first page.
    • Previous page to go back.
    • Next page to move to the next page.
    • Last page to go to the last page.
    You can directly navigate to a specific page by entering its number in the View bar and pressing Enter.
