Identity Management
Click Identity Management to navigate to the Identity Management page.
Figure 5-34 The Identity Management Page
You can manage users, groups, roles, functions, and also view the audit trail report from this page.
  • Users: The users who are mapped to the application are listed on this page.
    Figure 5-35 Identity Management Users
    This image displays the Identity Management Users.
  • Groups: The application admin users contain groups. This page displays the groups that are assigned to a user.
    Figure 5-36 Identity Management Groups
    This image displays the Identity Management Groups.
    Select a group to view or add details about it on the Group Details page. The Details tab is open by default.
    Figure 5-37 Group Details - Details
    This image displays the Group Details.
    Additionally, click the Mapped Roles tab to view details about roles that are mapped to specific groups.
    Figure 5-38 Group Details - Mapped Roles
    All the groups have specific roles mapped to it.
    • New Mapping: Click New Mapping to map a role to a group via the Unmapped Roles page. On this page, select the desired roles and click Map. You can also search for a specific role by entering the name of the role in the Search field and then clicking the search icon.
      Figure 5-39 Unmapped Roles
      Unmapped Roles
    • Unmap:Select the Role(s) that you want to unmap and then click Unmap.
      If a user has logged in and then mapped the role and group with a specific user credential, then, they can unmap only other groups, and not the user group they have logged in with.
    • Authorization: When you need to map a new role, you request for a new role or user group mapping. Select the Authorization View toggle. The Authorize and Reject button appear. To authorize or approve the role or group, select Authorize. To reject the request, click Reject.
      Figure 5-40 Authorization View screen
      This image displays the Authorization View screen in Admin.
  • Roles: The application admin users contain roles. This page displays the roles that are assigned to a user.
    Figure 5-41 Roles
    This image displays the Identity Management Roles.
    Select a to view or add details about it on the Roles Details page. The Details tab is open by default.
    Figure 5-42 Role Details
    Role Details
    Additionally, click the Mapped Functions tab to view details about roles that are mapped to specific functions.
    Figure 5-43 Mapped Functions
    Mapped Functions
    All the roles have specific functions mapped to it.
    • New Mapping: Click New Mapping to map a role to a function via the Unmapped Functions page. On this page, select the desired functions and click Map. You can also search for a specific function by entering the name of the function in the Search field and then clicking the search icon.
      Figure 5-44 Unmapped Functions
      Unmapped Functions
    • Unmap:Select the function(s) that you want to unmap and then click Unmap.
    • Authorization: Select the Authorization View toggle. The Authorize and Reject button appear. To authorize or approve the role or function, select Authorize. To reject the request, click Reject.
      Figure 5-45 Authorization View
  • Functions: View the list of functions on this page. Click a specific function to view or add details about it. You can also search for a specific function by entering the name of the function in the Search field and then clicking the search icon.
    Figure 5-46 Functions
    This image displays the Functions.
  • Audit Trail: The audit trail report reflects the activities the user performs during a particular period.
    Figure 5-47 Audit Trail Report
    This image displays the Audit Trail Report.
    • User Name:Click the arrow to select a user name from the drop-down list.
    • Action: Click the arrow to select an action from the drop-down list
    • From Date: Click the Select Date. icon to select a from date.
    • To Date:Click the Select Date. icon to select a to date.
    • Action Detail: Enter a value in this field.
    • Reset: Click this button to reset the data in the audit trail report.
    • Search: Click the search button to track a particular activity.
