Insight to Customize and Arrange Data in a Graph
Using Graph Customization options, you can provide more highlights (such as labels and vertices) to enrich the executed graph.
The graph can be customized based on your visual needs. The graph customization and settings are based on the configuration in the graph settings, such as Setup, Customization, Highlights, and Smart Explorer.
The following figure is customized using Customization in the Graph Settings.
Figure 9-34 Graph Customization
