Searching for Manual Decisions
This topic describes the systematic instructions to search the manual decision actions.
You can specify the Advanced Search using AND logic. It will display the edges only when they satisfy the search criteria.
To filter edges in the Advance Search, follow these steps:
  1. Click Advanced Search. The Advanced Search window is displayed.
  2. Select the fields from the Select Fields drop-down list. You can add multiple search criteria.
  3. You can perform the following actions:
    1. Click Add icon to add the field value for the selected field.
    2. Click Editicon to edit the field value for the selected field.
    3. Click Delete icon to delete the field value for the selected field, if required.
    4. Click Apply to display edges per search condition or click Cancel to Cancel.
    5. Click Reset to clear the specified values.
