Workflow for Merge and Split Global Entities
This topic described workflow for the Merge and Split Global Entities.
You can take the following actions as an Analyst (New tab) or Supervisor (New tab))
on this page:
- Merge
- Split
- Rearrange
- Create Group
As a Supervisor, you can make a decision on the following actions taken by
the Analyst.
- Approve
- Approve All
- Reject
The following figure illustrates the Merge and Split Global Entities workflow.
Figure 9-21 Merge and Split Global Entities workflow
