5.2.4.1 Behavioral Model Aggregate Base Features
- This pre-seeded batch will be available in all the workspaces
(Production and Sandboxes ).
This batch has to be executed in the Sandbox workspace. - This batch creates base features for scenario model training in the sandbox workspace.
Figure 5-29 Define Task for Aggregate_Base_Features
- Objective folder for this task:
Home / Modeling / Pipelines / ML4AML / Scenario Model / Batch / Base FeaturesNote:
Do not change any parameter except Optional Parameters. - Optional Parameters:
- model_group_name: Name of the Model Group for which Base Feature Aggregation is to be created. Example: LOB1.
- model_name: Name of the Model used while importing the model template using Admin Notebook. Example: RMF.
- from_date: The start date for the Historic Data lookup is in DD-MM-YYYY format.
- to_date: End Date for Historic Data lookup in DD-MM-YYYY format.
- prod_flag: Flag to indicate Training/Scoring scenario. The option is Y or N.
- For sandbox/historic training scenarios, the prod_flag should be set to N.
- include_full_lookback: Flag to indicate whether the lookback should consider data beyond the from_date to aggregating base features. The option is Y or N. The parameter is only applicable for training batch.
- For example, assume
from_dateis 01-Jan-2025,to_dateis 31-Dec-2025, the scenario runs weekly (frequency = 7), and the lookback period is 14 days. While calculating aggregates, the lookback window may eventually reach 05-Jan-2025. Since the configured from_date is 01-Jan-2025, only five days of data are available for this window, making it a partial lookback period. - The
include_full_lookbackparameter determines whether this partial period is included or excluded. To include a complete 14-day lookback for 05-Jan-2025, setfrom_dateto 23-Dec-2024. This ensures that the full analysis period from January through December 2025 is covered with complete lookback windows.
- last_run_date: The last run date within the from_date and to_date range, which exactly matches the scenario run date in DD-MM-YYYY format. The parameter is only applicable for training batch. It must be less than or equal to to_date. The required dates could be retrieved from the KDD table, where production run details are recorded.
- The
last_run_dateparameter specifies the scenario’s most recent actual run date lies withinfrom_dateandto_date. For example, iffrom_dateis 01-Jan-2025,to_dateis 31-Dec-2025, the scenario runs weekly (frequency = 7) with a 14-day lookback, valid run dates include 28-Dec-2025, 21-Dec-2025, and 14-Dec-2025. last_run_datemust be one of these valid run dates so that each event’salert_datecan be correctly mapped to the corresponding scenario run. Iflast_run_dateis set to 28-Dec-2025, the effectiveto_datebecomes 28-Dec-2025, and the first lookback period is calculated from that date.
- The
- frequency: The frequency of the scenario execution.
For example: 1 (Daily), 7 (Weekly), 14 (Bi-weekly), 30/31 (Monthly).
- For monthly scenarios, the frequency must always be set to 30, as aggregates are calculated at the monthly level.
- look_back: The lookback period for the scenario. For example: 30. For monthly scenarios, the
look_backmust always be set to 30, as aggregates are calculated at the monthly level. - focus: The model entity name is provided in the Admin notebook dataframe while creating the model group. The option is CUSTOMER or ACCOUNT.
Figure 5-30 Parameters for Aggregate Base Features
filters: Scenario specific parameters that are used to give additional control for the base feature aggregation. The format to be provided is as follows:
Param1 : Value1 ~ Param2 : Value2a | Value2b | Value2c
For example: PRIMARY_CUST_FL : Y ~ MANTAS_BUSINESS_ACCT_TYPES : RBK | RBR ~ INCL_CASH_TRXN_PRDCT_TYPE_LST:DEBIT-CARD|SVC|CREDIT-CARD|CURRENCY|PHYS
Figure 5-31 Edit Task for Aggregate Base Features
Table 5-4 Task Parameters for Scenario Model Aggregate Base Features
| Parameter | Description |
| PRIMARY_CUST_FL | It indicates what accounts are included by customer focus. The values are:
| INCLUDE_B28_TRNFR_FL | It controls the inclusion or exclusion of bank-to-bank transactions. The values are:
| INCLUDE_TRUSTED_TRANS_FL |
It controls the inclusion or exclusion of transactions designated as trusted transactions. Trusted transactions are those considered trusted based upon the presence of one or more trusted pairs (parties identified as enjoying a trusted relationship) on the transaction. The values are:
| INCL_RLTD_PARTIES | It allows coverage of all transactions between related parties. The values are:
| RPTNG_CURR_FL | The value is Y or N.
If Y, then all aggregation is to be done on reporting currency. |
| MIN_HRG_RISK_LVL | Minimum list risk level greater than or equal to (>=) a transaction considered high risk. |
| INCL_SEC_PARTY_FL | It controls the inclusion or exclusion of secondary parties. The value is Y or N. |
| EFFCTV_RISK_CUTOFF_LVL | The effective risk level is specified for the conditional thresholds, which will be decided for overall risk. |
| ACTVTY_RISK_CUTOFF_LVL | The activity risk level is specified for the conditional thresholds, which will be decided for overall risk. |
| INCLD_ACCT_HLDR_TYP_CD | List of Account Types included by the scenario. |
| MANTAS_BUSINESS_ACCT_TYPES | Codes that identify the business purpose or usage of this account for scenarios. |
| FUNC_CURR_FL |
The value is Y or N. If Y, all aggregation will be done on the functional currency. Note: If both reporting and functional currency are passed as “N”, then it will be considered as the base currency. |
| INCL_WIRE_TRXN_PRDCT_TYPE_LST | A list of transaction product type codes for wire transactions is included in the scenario. |
| INCL_MI_TRXN_PRDCT_TYPE_LST | A list of transaction product type codes for monetary instrument transactions is included in the scenario. |
| INCL_CASH_TRXN_PRDCT_TYPE_LST | A list of transaction product type codes for cash transactions is included in the scenario. |
| INCL_BO_TRXN_PRDCT_TYPE_LST | A list of transaction product type codes for back-office transactions is included in the scenario. |
| LRF_DIGITS | Considering the number of the last digit as zero for the round amount. |
| MIN_TRANS_ROUND_AMT | Considering the minimum amount for round amount. |
| MAX_TRANS_ROUND_AMT | Considering the maximum amount for round amount. |
| MIN_INDIVIDUAL_TRANS_AMT | Minimum supported amount for LRT scenario. |
| STRUCTURED_CASH_LIMIT_MIN | Lower limit used to be considered by Financial Institutions |
| STRUCTURED_CASH_LIMIT_MAX | Reporting limit used to be considered by Financial Institutions |
| DEGREE_OF_PARALLELISM | This should be configured properly for performance gain for SQL execution in parallel degree. |
| P_DAY_OF_FREQUENCY | This parameter should be used only for monthly batches. The frequency and lookback must be set to 30 and 30, respectively. The value can be either END or START:
| P_HISTORICAL | This parameter should be configured if historical aggregation is required for the current lookback. The value can be Y or N. |
| P_HISTORICAL_LOOKBACK | It indicates the number of historical lookbacks to consider. For monthly batches, the default is 12 months, and for others, it is 3 months. This parameter is configurable and takes the number of months as input.
To configure this parameter, the P_HISTORICAL parameter must be set to Y. |
| P_OCCR_AMT_DIFF_PRCT | This parameter defines the minimum percentage difference between two consecutive transaction amounts in group occurrence features. The default value is 2%. |
| P_OCCR_MIN_CNT | This parameter defines the minimum number of transactions in a cluster for occurrence features. The default value is 3. |
| P_AGG_CUST_MIN_NW | This parameter defines the minimum customer net worth cutoff for Aggregate Customer Net Worth/Depreciation features. The default value is 50,000. |
| P_AGG_CUST_MIN_DEP | This parameter defines the minimum customer depreciation cutoff for Aggregate Customer Net Worth/Depreciation features. The default value is 0. |
| P_AGG_CUST_MIN_DEP_PRCT | This parameter defines the minimum customer depreciation percentage cutoff for Aggregate Customer Net Worth/Depreciation features. The default value is 85%. |
| P_WIRE_TRANS_ROUND_PRCT | This parameter defines the minimum wire transaction rounding percentage for Wire Qualified features. The default value is 50%. |
Example for Weekly/Biweekly Matches: model_group_name=VALIDATION, model_name=RMF_LRT, from_date=01-Jan- 2012, to_date=31-Dec-2017, prod_flag=N, include_full_lookback=N, last_run_date=09-May-2016, frequency=7, look_back=30, focus=CUSTOMER, filters=PRIMARY_CUST_FL:Y~INCLUDE_B2B_TRNFR_FL:Y~INCLUDE_TRUSTED_TRANS_FL:Y~I NCL_RLTD_PARTIES:Y~RPTNG_CURR_FL:N~MIN_HRG_RISK_LVL:10~INCL_SEC_PARTY_FL:Y~E FFCTV_RISK_CUTOFF_LVL:10~ACTVTY_RISK_CUTOFF_LVL:10~INCLD_ACCT_HLDR_TYP_CD:C R~MANTAS_BUSINESS_ACCT_TYPES:RBK|RBR~FUNC_CURR_FL:Y~INCL_WIRE_TRXN_PRDCT_ TYPE_LST:EFT-ACH|EFT-TREASURY|EFT-FEDWIRE|EFT-SWIFT|EFTOTHER| EST~INCL_MI_TRXN_PRDCT_TYPE_LST:CASH-EQ-CASHIER-CHECK|CASH-EQ-CERTCHECK| CASH-EQ-MONEY-ORDER|CASH-EQ-TRAVELERS-CHECK|CASH-EQ-OTHER|CASHLETTER| CHECK|PAPER-OTHER|CHECK-ACH~INCL_CASH_TRXN_PRDCT_TYPE_LST:DEBITCARD| SVC|CREDITCARD| CURRENCY|PHYS~INCL_BO_TRXN_PRDCT_TYPE_LST:JOURNAL~LRF_DIGITS:4~MIN_T RANS_ROUND_AMT:10~MAX_TRANS_ROUND_AMT:100000000~MIN_INDIVIDUAL_TRANS_A MT:10~STRUCTURED_CASH_LIMIT_MIN:10~STRUCTURED_CASH_LIMIT_MAX:1000~DEGREE_ OF_PARALLELISM:8~P_HISTORICAL:Y~P_HISTORICAL_LOOKBACK:4~P_OCCR_AMT_DIFF_PRCT:2~P_OCCR_MIN_CNT:3~P_AGG_CUST_MIN_NW:50000~P_AGG_CUST_MIN_DEP:0~P_AGG_CUST_MIN_DEP_PRCT:85~P_WIRE_TRANS_ROUND_PRCT:50
Example for Monthly Batches: model_group_name=VALIDATION, model_name=RMF_LRT, from_date=01- Jan- 2012, to_date=31-Dec-2017, prod_flag=N, include_full_lookback=N, last_run_date=31-Dec-2016, frequency=30, look_back=30, focus=CUSTOMER, filters=PRIMARY_CUST_FL:Y~INCLUDE_B2B_TRNFR_FL:Y~INCLUDE_TRUSTED_TRANS _FL:Y~I NCL_RLTD_PARTIES:Y~RPTNG_CURR_FL:N~MIN_HRG_RISK_LVL:10~INCL_SEC_PARTY _FL:Y~E FFCTV_RISK_CUTOFF_LVL:10~ACTVTY_RISK_CUTOFF_LVL:10~INCLD_ACCT_HLDR_TY P_CD:C R~MANTAS_BUSINESS_ACCT_TYPES:RBK| RBR~FUNC_CURR_FL:Y~INCL_WIRE_TRXN_PRDCT_ TYPE_LST:EFT-ACH|EFT- TREASURY|EFT-FEDWIRE|EFT-SWIFT|EFTOTHER| EST~INCL_MI_TRXN_PRDCT_TYPE_LST:CASH-EQ-CASHIER-CHECK|CASH-EQ- CERTCHECK| CASH-EQ-MONEY-ORDER|CASH-EQ-TRAVELERS-CHECK|CASH-EQ- OTHER|CASHLETTER| CHECK|PAPER-OTHER|CHECK- ACH~INCL_CASH_TRXN_PRDCT_TYPE_LST:DEBITCARD| SVC|CREDITCARD| CURRENCY|PHYS~INCL_BO_TRXN_PRDCT_TYPE_LST:JOURNAL~LRF_DIGITS:4~MIN_T RANS_ROUND_AMT:10~MAX_TRANS_ROUND_AMT:100000000~MIN_INDIVIDUAL_TRAN S_A MT:10~STRUCTURED_CASH_LIMIT_MIN:10~STRUCTURED_CASH_LIMIT_MAX:1000~DE GREE_ OF_PARALLELISM:8~P_DAY_OF_FREQUENCY:END~P_HISTORICAL:Y~P_HISTORICAL_LOOKBACK:15~P_OCCR_AMT_DIFF_PRCT:2~P_OCCR_MIN_CNT:3~P_AGG_CUST_MIN_NW:50000~P_AGG_CUST_MIN_DEP:0~P_AGG_CUST_MIN_DEP_PRCT:85~P_WIRE_TRANS_ROUND_PRCT:50
- Edit Task Parameters and Save.
Parent topic: Batch Framework for Behavioral Model
