Document Control
Table - Document Control
| Version Number | Revision Date | Change Log |
| 8.1.2.7.0 | March 2024 |
Updated description for Candidate Selection in the Entity Resolution section. Added ER Type as CSA_8127 in the Creating Match/Merge Ruleset section. Updated Type field in the Adding a Data Store section. The term API Configurations has been changed to API Registry in the API Registry section. Added the following sections:
Added Python Runtime field in the Define Pipeline Characteristics section. |
