5.2.9 Modify Conda Settings
To modify the Conda Settings:
- Click the Conda Environments icon to navigate to the
Environment Summary page from any other window in the
application.This page displays the Conda environments in a tabular format.
- Click the Conda Settings icon.The Manage Conda screen is displayed.
Figure 5-26 Manage Conda screen
- Select the required option and click Clean.
- All: Removes index cache, lock files, unused cache packages, and tarballs.
- Index Cache: Removes index cache.
- Packages: Removes unused packages from writable package caches. WARNING: This does not check for packages installed using symlinks back to the package cache.
- Tarballs: Removes cached package tarballs.
- Log Files: Removes log files.
This will clean up the Conda components based on the selection.
