A.7 APIs for Model Pipelines
All the listed APIs/Functions can be utilized by users in Model Pipelines.
Table A-3 Python Paragraph Scripting
| API Type | Functionality | Prerequisite | Notebook Execution Script | Notebook Script Input | Minimum Supported Version |
| Set User | Set the user for a session |
%python from mmg.constants import * user = "SAUSER" set_user(user) |
user - username to be set | 8.1.1 | |
| Get User | Get the user that has been set | Set User |
%python from mmg.constants import * get_user() |
8.1.1 | |
| Attach Workspace | Attach the workspace for a session |
%python from mmg.workspace import attach_workspace workspace = "CS" attach_workspace(workspace) |
workspace- workspace to be attached | 8.1.1 | |
| Get Workspace | Get the workspace that has been attached | Attach Workspace |
%python from mmg.workspace import get_workspace get_workspace() |
8.1.1 | |
| List Workspaces | Lists all workspaces available to a user | Set User |
%python from mmg.workspace import list_workspaces list_workspaces() |
8.1.1 |
| Check AIF | Check if AIF is set or not | Set User |
%python from mmg.workspace import check_aif check_aif() |
8.1.1 |
| List All Data Sources | List all data sources available in a workspace for a set user. The default workspace chosen is the one that is attached. | Set User, Attach Workspace |
%python from mmg.workspace import list_datasources list_datasources(order=None) |
order - None ensures that all the data sources will be listed for the attached workspace | 8.1.1 |
| List All Data Sources of Workspace | List all Data Sources of a specific Workspace that is not the attached workspace for a set user. | Set User |
%python from mmg.workspace import list_datasources workspace="HELLO NEW" list_datasources(workspace,order=None) |
workspace - Name of workspace for which data sources should be listed order - None ensures that ALL data sources will be listed for that workspace |
8.1.1 |
| Fetch First Order Data Source | This method will fetch the data source related to attached workspace with default order 1. | Set User, Attach Workspace |
%python from mmg.workspace import list_datasources list_datasources() |
order - 1 by default, if not specified |
8.1.1 |
| Fetch First Order Data Source of Workspace | This method will fetch the data source with default order 1 related to specified workspace. | Set User |
%python from mmg.workspace import list_datasources workspace="CS" list_datasources(workspace) |
workspace - Name of workspace for which data source should be listed order- 1 by default if not specified |
8.1.1 |
| Fetch Nth Order Data Source | This method will fetch the data source related to attached workspace with given order | Set User, Attach Workspace |
%python from mmg.workspace import list_datasources list_datasources(order=2) |
order - Order of data source to be fetched | 8.1.1 |
| Fetch Nth Order Data Source of Workspace | This method will fetch the data source with given order related to specified workspace. | Set User |
%python from mmg.workspace import list_datasources workspace="CS" list_datasources(workspace,order=2) |
workspace - Name of workspace for which data source should be listed order = Order of data source to be fetched |
8.1.1 |
| Get Connection Object | Returns Oracle/ SQL Alchemy Connection Object to Data Source of order 1 in attached workspace. |
%python import cx_Oracle from mmg.workspace import get_connection conn=get_connection() if not isinstance(conn,cx_Oracle.connect): print("Not Connection Object") print(conn) |
8.1.2.0 | |
| Get Connection Object To Specific Data Source | Returns Oracle/ SQL Alchemy Connection Object to specified Data Source | Set User |
%python import cx_Oracle from mmg.workspace import get_connection datasource="DS001" conn=get_connection(datasource) if not isinstance(conn,cx_Oracle.connect): print("Not Conn Object") print(conn) |
datasource - Name of datasource for which the connection object has to be returned | 8.1.2.0 |
| Get Connection Object To Data Source Using Order | Returns Oracle/ SQL Alchemy Connection Object to Data Source of specified order in attached workspace. | Set User, Attach Workspace |
%python import cx_Oracle from mmg.workspace import get_connection datasource=2 conn=get_connection(datasource) if not isinstance(conn,cx_Oracle.connect): print("Not Conn Object") print(conn) |
datasource - Order number of datasource in attached workspace for which the connection object has to be returned | 8.1.2.0 |
| Test Connection Object | This script can be used to test the connection object to data source |
Get Connection Object OR Get Connection Object To Specific Data Source OR Get Connection Object To Data Source Using Order |
%python query="SELECT table_name FROM user_tables" cur = conn.cursor() cur.execute(query) print(cur.fetchall()) if cur: cur.close() |
8.1.2.0 |
Table A-4 PYTHON LINEPARSER APIs (for MMG version 8.1.0)
| API Type | Functionality | Notebook Execution Script | Note |
%python mmg.attachWorkspace(workspace) #eg- mmg.attachWorkspace("CS") |
workspace - workspace to be attached (String) Sets 'mmg' python variable which contains the information about the attached workspace. Output- Print a boolean in one line on the status of workspace attachment and another line of boolean on status of AIF enabled and attached. |
%python mmg.listWorkspaces() |
Sets 'ofs_wsList' python variable which is the list of all available workspaces. Output- Print the list of workspaces. |
%python print(aif__isAttached) |
Output- Boolean on the status of AIF. |
| Get Connection Object | Returns cx_Oracle Connection Object |
%python mmg.getConnection(schema_name) #eg- mmg.getConnection("OFSAA") |
schema_name = name of the schema for which connection is required (String). Sets 'conn' python variable which is the cx_Oracle connection object to be used for firing queries. |
| Publish | Fetch and sets the Notebook JSON dump |
%python mmg.publish() |
Sets 'emf_para' python variable which is the JSON dump for the notebook component. Output- Print the set 'emf_para' value. |
| Register | Register the Notebook |
%python mmg.register(register) #eg- mmg.register({"modelname":"model1",\ # "modeldescription":"Model description"}) #eg- mmg.register(emf_para) {After doing mmg.publish()} |
register - JSON Stringify object for RegisterNotebookBean Object. Sets 'publishedNotebookId' python variable which is the studio notebook id for the published version. Output- Prints the published notebook id. |
| Load Flat File |
%python mmg.loadFlatFile() #eg- mmg.loadFlatFile() Incomplete |
| Profile Data |
%python mmg.profileData(code,title) #eg- mmg.profileData(ABC,XYZ) |
