Using Scenario Conversion Utility for ASC
Scenario Conversion Utility (SCU) converts BD scenarios to Compliance Studio notebooks for the scenarios and respective thresholds.
- The utility converts only BD AML scenarios to Compliance Studio notebooks based on the rule matcher algorithm.
- This section is applicable only if you are using Scenario Conversion Utility and Automated Scenario Calibration use case.
- Ensure that the OFS Compliance Studio v8.1.2.9.0 is installed and running.
- Make sure that all the Compliance Studio patches are applied.
- Ensure that the OFS BD v8.1.2.x.x is installed and running.
- Ensure that the following tables and sequence exist in the
Compliance Studio Schema:
- Tables:
- ds_notebook
- ds_paragraph
- Sequence:
- seq_paragraph
- Tables:
The calendar notebook is used to set calendar information and processing batch date for execution of the scenario notebook.
Import SCU_Set_Calendar.dsnb notebook
into the sandbox workspace and pointing to the non-prod BD atomic schema.
<OFS_COMPLIANCE_STUDIO_INSTALLATION_PATH>/
deployed/ficdb/Scenario-Conversion-Utility/db_tools/lib directory.
dbtools.jarkddcore.jarlog4j-api-<version>.jarlog4j-core-<version>.jar
A few OOB scenarios use re-alert lookback, which helps to avoid redundant alerts in AML. To incorporate the same in SCU, VW_REVIEW is used as a union of alerts in AML and events in SCU.
To ensure that previously alerted entities from AML are still considered in these scenarios, users can customize VW_REVIEW by creating it as shown below.
"CREATE OR REPLACE FORCE EDITIONABLE VIEW VW_REVIEW ("REVIEW_ID", "PRCSNG_DT", "CNTRY_KEY_ID") AS
SELECT
e.v_event_cd review_id,
e.prcsng_dt,
m.v_entity_cd cntry_key_id
FROM
fcc_am_events e,
fcc_am_event_entity_map m
WHERE
e.v_event_cd = m.v_event_cd
AND m.v_focus_flag = 'Y';"
