5.2.9 Modify Conda Settings
To modify the Conda Settings:
  1. Click the Conda Environments icon to navigate to the Environment Summary page from any other window in the application.
    This page displays the Conda environments in a tabular format.
  2. Click the Conda Settings icon.
    The Manage Conda screen is displayed.
    Figure 5-26 Manage Conda screen
    This image displays the Manage Conda screen.
  3. Select the required option and click Clean.
    • All: Removes index cache, lock files, unused cache packages, and tarballs.
    • Index Cache: Removes index cache.
    • Packages: Removes unused packages from writable package caches. WARNING: This does not check for packages installed using symlinks back to the package cache.
    • Tarballs: Removes cached package tarballs.
    • Log Files: Removes log files.
    This will clean up the Conda components based on the selection.
