2.2.2.2 Security within Enterprise Case Management
Analytical Applications Infrastructure (OFSAAI) uses five layers of security to control data access, as defined in . You can view a case if your combination of access controls authorizes you to view the event and business information. Contact your system administrator for details about your access control permissions.
The following describes the Access Controls for Enterprise Case Management.
Table 2-6 Access Controls for Enterprise Case Management
| Actions | Description | |
| Type | Controls | |
| Roles | Features and Functions | This security layer identifies the features and functions you can perform within the Enterprise Case Management. |
| Organizations | Case Information | This security layer enables your firm to restrict access using your firm's organizational hierarchy. To ensure accurate reporting, all users must be assigned one primary organization; however, a user can be assigned multiple viewable associations. To see a case owned by an organization or by the users within an organization, you must have viewable rights to that organization. |
| Business Domains | Case and Business Information | This security layer enables your firm to restrict access along operational business lines and practices. You can only see cases assigned to at least one of the same business domains. |
| Jurisdictions | Case Information | This security layer enables your firm to restrict access using geographic locations. You can only see cases that are assigned to the same jurisdictions. |
| Case Type | Case Information | This security layer enables your firm to restrict access by specific types of Investigations (a combination of Case Type). To see a case, you must have rights to view the specific Case Type assigned to the case. |
