3.1 System Requirements
The following applications are required to run the OFS ECM application:
Table 3-1 Configurations Supported for Java 8: Operating System
| Operating System | Version |
| Oracle Linux / Red Hat Enterprise Linux(x86-64) |
Oracle Linux Server release 7.5 and above - 64 bit Oracle Linux Server release 8 - 64 bit Note: Same version of RHEL is supported. |
| Oracle Solaris (SPARC) | 11.3+- 64 bit |
| Shell | KORN Shell (KSH) |
If the operating system is RHEL, install the package lsb_release with one of the following commands by logging in as root user:- yum install redhat-lsb-core
Table 3-2 Configurations Supported for Java 8: Java Runtime Environment
| Oracle Linux / Red Hat Enterprise Linux | Oracle Java Runtime Environment (JRE) 1.8.x - 64 bit |
| Oracle Database Server and Client |
Oracle Database Server Client 19.3+ Oracle Database Server Enterprise Edition 19.3+ - 64 bit RAC/ Non-RAC with/ without partitioning option |
- V 11.1.2.1+ (Server and Client) with Oracle 11g Database
- V 11.1.2.3+ (Server and Client) with Oracle 12c Database
- V 11.2.0.3+ with Oracle 11g Database
- V 12.1.0.1+ with Oracle 12c Database
Table 3-3 Configurations Supported for Java 8: Web Server/Application Server
| Oracle Linux / Red Hat Enterprise Linux/ IBM Solaris |
Oracle HTTP Server 11.1.1.1/ Apache HTTP Server 2.2.x/ IBM HTTP Server. Oracle WebLogic Server 12.2.x and 14.1.x - 64 bit IBM WebSphere Application Server 9.0.0.x with bundled IBM Java Runtime - 64 bit Apache Tomcat v9.0.x - 64 bit |
OFSAA Infrastructure web component deployment on Oracle WebLogic Server with Oracle JRockit is not supported. For deployment on Oracle WebLogic Server (64 bit) with Java 8, download from My Oracle Support.Table 3-4 Desktop Requirements
| Particulars | Version |
| Operating System | Windows 10 |
| Browser |
| Office Tools |
| Screen Resolution | Minimum screen resolution & Scaling must be 1366 * 768 with 100% scaling. |
Table 3-5 Other Software
| Particular | Version |
| Directory Services | OFSAAI is qualified on both OPEN LDAP 2.2.29+ and Oracle Internet Directory v 11.1.1.3.0. However, it can be integrated with other directory services software such as MS Active Directory. |
- l Configuration of Directory services software for OFSAAI installation is optional.
- l Open LDAP must be installed on MS Windows Server machine.
