20.4 System Parameters Deciding Entity Records to Car Cases
This section describes the combination of system parameters that decides which Entity records are copied to the CAR cases.
Let us consider following scenarios when both the Attribute 1 and Attribute 2 values are set to:
Table 20-4 System Parameters Deciding Entity Records to Car Cases
| Attribute 1 Value | Attribute 2 Value | Behavior/Description |
| N | N |
This is the default behavior. Only Entities marked as Suspect are moved to the Entities tab of the CAR case. However, the Involved Party (IP) records are not moved to the IP tab. |
| N | Y |
Only Entities marked as Suspect are moved to the Entities tab of the CAR case. However, all IP records are moved to IP tab irrespective of the Relation Type (Victim/Suspect/Other). |
| Y | N |
All Entities marked as Suspect are moved to the Entities tab of the CAR case. However, the Involved Party (IP) records are not moved to the IP tab. |
| Y | Y |
All Entities marked as Suspect are moved to the Entities tab of the CAR case. However, all IP records are moved to IP tab irrespective of the Relation Type (Victim/Suspect/Other). |
- Navigate to the Administration tab and select the Manage Parameters option.
- Select Manage Common Parameters to access the Manage Common Parameters window.
- Select UI For Design from the Parameter Category drop-down list.
- Select Data Transfer in CAR Case Creation from the Parameter Name drop-down list.
- Select the Attribute 1 and Attribute 2 values accordingly.
- Click Save.
- Click OK.
