3.4 Setting Preferences
The Preferences section enables you to set your OFSAA Home Page.
To access this section, follow these steps:
  1. Click Preferences from the drop-down list in the top right corner, where the user name displays.
    The Preferences screen displays.
  2. In the Property Value drop-down list, select the application which you want to set as the Home Page.
    Figure 3-7 Preferences
    Preferences
    Whenever a new application is installed, the related value for that application is found in the drop-down list.
  3. Define the date format. The default date format is MM/dd/yyyy. You can change this to dd/MM/ yyyy format.
    After changing the date format in Preferences UI, you should logout and login to the Application.
  4. Click Save to save your preference.
