3.1 System Requirements
The following applications are required to run the OFS ECM application:
The following table describes the versions of various operating systems.
Table 3-1 Configurations Supported for Java 8: Operating System
Operating System Version
Oracle Linux / Red Hat Enterprise Linux(x86-64)
Oracle Linux Server release 7.5 and above - 64 bit Oracle Linux Server release 8 - 64 bit
Same version of RHEL is supported.
Oracle Solaris (SPARC) 11.3+- 64 bit
Shell KORN Shell (KSH)
If the operating system is RHEL, install the package lsb_release with one of the following commands by logging in as root user:
  • yum install redhat-lsb-core
The following table describes the Java Runtime Environment.
Table 3-2 Configurations Supported for Java 8: Java Runtime Environment
Oracle Linux / Red Hat Enterprise Linux Oracle Java Runtime Environment (JRE) 1.8.x - 64 bit
Oracle Database Server and Client
Oracle Database Server Client 19.3+
Oracle Database Server Enterprise Edition 19.3+
- 64 bit RAC/ Non-RAC with/ without partitioning option
Operating System or Version:
  • V 11.1.2.1+ (Server and Client) with Oracle 11g Database
  • V 11.1.2.3+ (Server and Client) with Oracle 12c Database
  • V 11.2.0.3+ with Oracle 11g Database
  • V 12.1.0.1+ with Oracle 12c Database
The following table describes the various operating systems with versions for Web Server or Web Application Server
Table 3-3 Configurations Supported for Java 8: Web Server/Application Server
Oracle Linux / Red Hat Enterprise Linux/ IBM Solaris
Oracle HTTP Server 11.1.1.1/ Apache HTTP Server 2.2.x/ IBM HTTP Server.
Oracle WebLogic Server 12.2.x and 14.1.x - 64 bit
IBM WebSphere Application Server 9.0.0.x with bundled IBM Java Runtime - 64 bit
Apache Tomcat v9.0.x - 64 bit
OFSAA Infrastructure web component deployment on Oracle WebLogic Server with Oracle JRockit is not supported. For deployment on Oracle WebLogic Server (64 bit) with Java 8, download from My Oracle Support.
The following table describes the desktop requirements.
Table 3-4 Desktop Requirements
Particulars Version
Operating System Windows 10
Browser
  • Chrome Version 90.0.4430.212
  • l FirefoxVersion 78.10.1esr
  • MicrosoftEdge Version 90.0.818.62 Turnoff Pop-up blocker settings.
Office Tools
  • MS Office 2010/2013
  • l Adobe Acrobat Reader 8 or above
Screen Resolution Minimum screen resolution & Scaling must be 1366 * 768 with 100% scaling.
The following table describes the directory services.
Table 3-5 Other Software
Particular Version
Directory Services OFSAAI is qualified on both OPEN LDAP 2.2.29+ and Oracle Internet Directory v 11.1.1.3.0. However, it can be integrated with other directory services software such as MS Active Directory.
  • Configuration of Directory services software for OFSAAI installation is optional.
  • Open LDAP must be installed on MS Windows Server machine.
