7.1.6.1.4.1 Use Case flow for “Cur Par Bal Outliers” Analysis
You can refer this use case to best leverage the advanced analytics capabilities of the reports.
Starting from the canvas “Cur Par Bal Outliers” you can perform a series of actions as follows:
  1. Select your desired Sigma value on which the outlier analysis will be generated.
    Figure 7-125 Sigma Factor selection for STD Deviation
  2. Select the Outliers for any of the available Dimensions.
    Figure 7-126 Outliers Selection
    Outliers Selection
  3. Once you have selected a combination of Outliers and related dimensions, you can use the Data Actions to navigate to the other Report canvases or to the Process Results Data Analysis report.
    Figure 7-127 Data Actions Navigation
