PreviousNext
JavaScript must be enabled to correctly display this content
9.2.3.1 Running Hybrid Rate Generation using
Simplified Batch
To run Hybrid Rate Generation using Simplified Batch, follow these
steps:
Navigate to Common Object Maintenance, select
Operations, and then select Simplified
Batch.
(Optional) <Enter a step example.>
Click Add.
From the Task Details pane, click Select
Task. In the Task Selection window,
select Task Type as Transform
Data. Click Search. In the Task
Selector, select the IRC_HYBRID_SCHEDULER
and click Ok.
Enter the Parameters and click Save.
In the Simplified Batch Summary page, search the Hybrid
Rate Generation batch, and select it. Click the Run
icon.
Click Yes to confirm you want to continue, enter a date
(this will be your TO DATE), and click Ok to continue. A
confirmation message is displayed.
Click Ok. When the batch is complete, navigate to
Operations and select View Log to view the processing log.
Any error messages or warnings are accessible from the View Log window.
Simplified Batch does not provide access to logs for Transform Data
tasks.
For more information, see the OFS Analytical Applications Infrastructure User
Guide.
