5.10.1 Configure Operating System and File System Settings
Log in as a root user and create the .profile file at the home directory
of the logged-in user if it is not already available. The user must have 755 permission
on the file to execute it. This file consists of various parameters for Environment
Settings, OS, and File System Settings.
Table 5-6 Configure Operating System and File System Settings
| Parameter | Configuration Action |
| File Descriptor Settings |
In the
fs.file-max = <value> where
NOTE: The value specified here is the minimum value to be set for the installation process to go forward. For other modules, this value may depend on the available resources and the number of processes executed in parallel. |
| Total Number of Process Settings |
In the NOTE: The value specified here is the minimum value to be set for the installation process to go forward. For other modules, this value may depend on the available resources and the number of processes executed in parallel. |
| Port Settings | Default port numbers to be enabled on the system are 6500, 6501, 6505, 6507, 6509, 6510, 6666, 9999, and 10101. |
| OS Locale |
Linux: en_US.UTF-8 Solaris: en_US.UTF-8 To check the locale installed, execute the following command:
| Installation Directory | In the .profile file, set the variable FIC_HOME
to point to the OFSAA Installation Directory.
| .profile permissions | You must have 755 permission on the .profile
file.
.profile file, login as a non-root user,
and configure the environment settings.
Do not modify any other parameters other than the parameters mentioned in the following subsections.
