7.10.3.2 Define JDBC Connection Pooling
To define the JDBC connection pooling, follow these steps:
The User-IDs for configuration/ atomic schemas have the prefix of setupinfo
depending on the value set for PREFIX_SCHEMA_NAME in the <<APP Pack>>_
SCHEMA_IN.XML file of Schema Creator Utility.
For example: if the value set for PREFIX_SCHEMA_NAME is DEV and the schema name is mentioned as ofsaaconf, then the actual schema created in the database is DEV_ofsaaconf.
