6.6.4 Amortization Detailed Report by Product
This is the fourth canvas under Amortization Reports. The above-mentioned pinned global filters and additional dimension-based filters i.e. Product Hierarchy and Product Leaf are required to generate this report. If Multiple product hierarchies are present, then it is ideal to select a single product hierarchy. Product leaves can be selected based on the selection of product hierarchy. The Product is a hierarchy-based dimension so this report will provide amortization measures at product hierarchy levels.
Figure 6-61 Amortization Detailed Report by Product Report
