6.4.1.4 Stage Transition Matrix by Product
This is the fourth canvas under Stage Transition Reports. The
above-mentioned pinned global filters and additional dimension-based filters
i.e., Product Hierarchy, and Product Leaf are required to generate this
report. If Multiple product hierarchies are present, then it is ideal to
select a single product hierarchy. Product leaves can be selected based on
the selection of product hierarchy. The product is a hierarchy-based
dimension so this report will provide a count and the percentage of the
count of accounts across various stages at product hierarchy levels.
Figure 6-26 Stage Transition Matrix by Product Report
