Stage Transition Matrix by Legal Entity
This is the first canvas under Stage Transition Reports. The above-mentioned pinned global filters are enough to generate the report. The legal entity is a hierarchy-based dimension so this report will provide a count and the percentage of the count of accounts across various stages at legal entity hierarchy levels. These reports can be viewed as Standalone or Consolidated reports.
To generate the below reports following dimensions are used: As of date, Modelling Set, Consolidation Type, Legal Entity Hierarchy Name, and Legal Entity Node.
Figure 6-29 Stage Transition Matrix by Legal Entity Report
