Stage Trends by Industry
This is the fifth canvas under Stage Trends Reports. The above-mentioned pinned global filters and additional dimension-based filters i.e., Industry Hierarchy, and Industry Leaf are required to generate this report. If Multiple industry hierarchies are present, then it is ideal to select a single industry hierarchy. Industry leaf can be selected based on the selection of industry hierarchy. The industry is a hierarchy-based dimension so this report will provide a count and the percentage of the count of accounts across various stages at industry hierarchy levels.
These reports can be viewed as Standalone or Consolidated reports.
To generate the below reports following dimensions are used: As of date, Modelling Set, Consolidation Type, Legal Entity Hierarchy Name, Legal Entity Node, Industry Hierarchy Name, and Industry Node.
Figure 6-42 Stage Trends by Industry Report
Figure 6-43 Stage Trends by Industry Report
