Summary
This canvas supports both standalone and consolidated reports.
To generate the below reports following dimensions are used: Base Run Date, Inspect Run Date, Modelling Set Name, Consolidation Type, Legal Entity Node, and Reporting Currency Name.
Additionally, you can drill-down to view the details of an Attribute. The Detail-1 report is available only for Change in exposure and Risk Parameters. Right-click the desired attribute bar or attribute name and then select Detailed-1.
Figure 6-251 Attribution Analysis - ECL
Figure 6-252 Attribution Analysis - ECL
