3.4.3.2 Adding Data to Table – Forms Created Using Data Entry
If the Forms Definition is created using the designer option, the user with the necessary role can add or delete records and also update the values for the table records as per the configuration in the Forms Definition.
These records are then submitted for approval to another user with the
necessary role. For more information, refer to User Role Mapping and Access Rights.
To update/delete data in the table records:
Related Topics
