5.1 Amend Out-of-the-Box Reports
A user with DV Content Author privileges will have access to amend and save the out-of-the-box reports.
To amend and save the reports:
- To open the ORACLE Analytics page, from the Home Page, select Home Page, and then from the Page Menu on the top-right corner, select Open Classic Home.
A new window will open with Classic Home.
- Click Catalog.
- Navigate to Shared Folders and select the dashboard and subsequently the report from the available list that you want to edit and right click on your mouse. You will find the Copy option as indicated in the below illustration.
- Navigate to My Folders.
- Paste the report.
You will be able to edit the Report which is saved inside My Folder.
